Salta al contenuto principale
Window Operator Link Replacement
Cosa ti serve
  1. Window Operator Link Replacement, Link: passo 1, immagine 1 di 2 Window Operator Link Replacement, Link: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Flathead 4 mm Screwdriver
    $5.49
    Compra
    • Remove the four (4) window clips that holds the screen.
    • Your amount of window clips may vary depending on the size of your window.
    • Use the Flathead 4 mm Screwdriver to loosen the clip. The clip doesn't need to be removed.
    • Remove the screen and put it aside.
  2. Window Operator Link Replacement: passo 2, immagine 1 di 3 Window Operator Link Replacement: passo 2, immagine 2 di 3 Window Operator Link Replacement: passo 2, immagine 3 di 3
    Large Needle Nose Pliers
    Compra
  3. Window Operator Link Replacement: passo 3, immagine 1 di 3 Window Operator Link Replacement: passo 3, immagine 2 di 3 Window Operator Link Replacement: passo 3, immagine 3 di 3
    • Using the Phillips #2 Screwdriver , remove the two bolts that are holding the operator into the window frame.
    • Behind the window, you will have one self retaining nut per bolt.
    • In some cases, you will need to play with the operator in order to take it out due to the small tolerances in the window.
  4. Window Operator Link Replacement: passo 4, immagine 1 di 3 Window Operator Link Replacement: passo 4, immagine 2 di 3 Window Operator Link Replacement: passo 4, immagine 3 di 3
    Metal Spudger
    $2.99
    Compra
  5. Window Operator Link Replacement: passo 5, immagine 1 di 3 Window Operator Link Replacement: passo 5, immagine 2 di 3 Window Operator Link Replacement: passo 5, immagine 3 di 3
    Compra
    • Once the warped or broken link is removed, follow the Step 4 in reverse order.
    • You may use the Large Needle Nose Pliers to force the e-clip into place.
Conclusione
To reassemble your device, follow from step three (3) to one (1) in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 46
Tutti i Tempi: 952
