Salta al contenuto principale
Wiko Getaway Screen Panel Replacement
Cosa ti serve
Panoramica Video
  1. Wiko Getaway Screen Panel Replacement, Back cover: passo 1, immagine 1 di 3 Wiko Getaway Screen Panel Replacement, Back cover: passo 1, immagine 2 di 3 Wiko Getaway Screen Panel Replacement, Back cover: passo 1, immagine 3 di 3
    • Broken screen ? that's a pity
    • You'll need hot air. Not too much thought, you'll melt the plastic otherwise
    • Now just pry it open SLOWLY and apply heat.
  2. Wiko Getaway Screen Panel Replacement, Disconnect stuff: passo 2, immagine 1 di 3 Wiko Getaway Screen Panel Replacement, Disconnect stuff: passo 2, immagine 2 di 3 Wiko Getaway Screen Panel Replacement, Disconnect stuff: passo 2, immagine 3 di 3
    • Nice, I see you've got the cover off
    • Disconnect the battery (not with a metal tool)
    • Disconnect the touch screen ribbon (don't pull hard, you have to lift the plastic bit before)
  3. Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: passo 3, immagine 1 di 3 Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: passo 3, immagine 2 di 3 Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: passo 3, immagine 3 di 3
    • Get the battery out (don't bend it too much)
    • Disconnect the LCD ribbon
    • Disconnect the cameras
  4. Wiko Getaway Screen Panel Replacement, Screws ! Finally: passo 4, immagine 1 di 3 Wiko Getaway Screen Panel Replacement, Screws ! Finally: passo 4, immagine 2 di 3 Wiko Getaway Screen Panel Replacement, Screws ! Finally: passo 4, immagine 3 di 3
    • Unscrew anything you see
    • Take the SIM trays out
    • Take the motherboard out. You will have to disconnect to ribbon cables
  5. Wiko Getaway Screen Panel Replacement, Final: passo 5, immagine 1 di 3 Wiko Getaway Screen Panel Replacement, Final: passo 5, immagine 2 di 3 Wiko Getaway Screen Panel Replacement, Final: passo 5, immagine 3 di 3
    • Two screws here
    • To take this guy out, you can use heat again
    • Aaaaand with more heat, you will get the screen panel out !
Conclusione
Altre 4 persone hanno completato questa guida.
The Repair Academy Membro di The Repair Academy
Business
1 Membro
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,035
