Salta al contenuto principale
Introduzione
This guide will help you to remove the outer case and be able to open the Nintendo Wii U Gamepad. You will need a Tri-WIng Y1 screw driver.
  1. Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
    tried to unscrew the 10 Tri-Wing size Y1 screw with my iFixIt toolkit
    unfortunately the tool is too “fat” and short, it cannot reach 4 screws on the corners of the gamepad.
    having the iFixIt toolkit and needing to purchase an additional slim screwdriver it’s a shame…
    Antonello Iannone - Replica
  2. Lift and remove the battery plate.
    • Lift and remove the battery plate.
  3. With your finger, press down and pull back on the battery connector plug. Remove the battery from the battery case. Remove the battery from the battery case.
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
    Battery lifts up from the bottom not the top like the photo shows.
    Tyler Schommer - Replica
  4. Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case. Lift up on the back of case. Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
    I used a small blade tip to life up on the black squares that covered the screw holes. Replacing them after.. I skipped that as it seemed impossible they would even stick back down.
    Chris - Replica
    I am having trouble getting the two screws on the hand grips as the screws are too deep. What should I use to get them?
    Essma - Replica
    I ended up having to buy some cheap amazon screwdrivers and are very disappointed
    Essma -
  5. Unplug outer case rumble motor connector from the motherboard with your fingers.
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
    Do not pull by the wires! If you do, you better be pretty good at soldering.
    Brandon - Replica
    I agree. A circle over the plug would have been better as the picture looks like you just pull on the wires lol.
    Chris -
    Great. Didn't pull on cord. Whole thing ripped off.
    August - Replica
    Why in the world is this thing so tightly connected?
    Andrew Moore - Replica
Conclusione
Altre 4 persone hanno completato questa guida.
Valentina Cerruty
Membro da: 10/02/2016
2.815 Reputazione
7 Guide realizzate
USF Tampa, Team 1-6, Sullivan Spring 2016 Membro di USF Tampa, Team 1-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G6
4 Membri
34 Guide realizzate
Un commento
This doesn't show anything about taking the front of the housing off, is that relatively straightforward?
Will Prosser - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 55
Tutti i Tempi: 2,867
