Introduzione
This guide will help you to remove the outer case and be able to open the Nintendo Wii U Gamepad. You will need a Tri-WIng Y1 screw driver.
Strumenti
Parti
Nessuna parte specificata.
Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
Altre 3 persone hanno completato questa guida.
Un commento
This doesn't show anything about taking the front of the housing off, is that relatively straightforward?
