Salta al contenuto principale
Wii U GamePad Outer Case Replacement
Cosa ti serve
  1. Wii U GamePad Outer Case Replacement, Battery: passo 1, immagine 1 di 2 Wii U GamePad Outer Case Replacement, Battery: passo 1, immagine 2 di 2
    • Face the GamePad down and unscrew the two Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. Wii U GamePad Outer Case Replacement: passo 2, immagine 1 di 3 Wii U GamePad Outer Case Replacement: passo 2, immagine 2 di 3 Wii U GamePad Outer Case Replacement: passo 2, immagine 3 di 3
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
  3. Wii U GamePad Outer Case Replacement, Outer Case: passo 3, immagine 1 di 3 Wii U GamePad Outer Case Replacement, Outer Case: passo 3, immagine 2 di 3 Wii U GamePad Outer Case Replacement, Outer Case: passo 3, immagine 3 di 3
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
    how do i replace the whole front and back casing?
    enbodylin - Replica
    bruh the ifix it screwdriver dont reach down the whole way
    Michael - Replica
    I feel like it’s important to mention how deep some of these holes are. Your screwdriver might not reach. Mine sure didn’t.
    greatshadowdude - Replica
    I had to shove some tissue into the screwdriver bit holder to get it to reach
    Andrew Walker - Replica
  4. Wii U GamePad Outer Case Replacement: passo 4, immagine 1 di 2 Wii U GamePad Outer Case Replacement: passo 4, immagine 2 di 2
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back plate.
    You don't have to remove just be careful
    Heather Sheppard - Replica
    I tried to remove like at least 6 times but I wasn’t able to. Using tweezer, my nails, long nose pliers. There could be a lock but I gave up since I’m afraid if I put more force I might accidentally pull the wires. I’m able to remove the left and right analog stick with the back plate plugged, as mentioned, just be careful.
    Royce Remulla - Replica
    I was stuck on this step for a while - note that you’re only removing the little white plastic bit. The beige or yellowish plastic bit is attached to the board. I needed to use pliers to carefully grab just the white plastic bit and wiggle it side to side.
    Nova H - Replica
Conclusione
Altre 11 persone hanno completato questa guida.
Kim Arre
Membro da: 01/11/13
4.918 Reputazione
8 Guide realizzate
Cal Poly, Team 17-20, Forte Winter 2013 Membro di Cal Poly, Team 17-20, Forte Winter 2013
CPSU-FORTE-W13S17G20
5 Membri
38 Guide realizzate
2 Commenti
This is either incomplete or mistitled - it is a currently a back plate replacement guide.
At the conclusion of this how-to/walkthrough, most of the GamePad's hardware is still attached to the front plate, one half of the outer case.
Elijah - Replica
and the front?
Raul Kim Diego - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 117
Tutti i Tempi: 14,616
