Salta al contenuto principale
Wii U GamePad Battery Replacement
Cosa ti serve
  1. Wii U GamePad Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
  2. Wii U GamePad Battery Replacement: passo 2, immagine 1 di 1
    • Lift and remove the battery plate.
  3. Wii U GamePad Battery Replacement: passo 3, immagine 1 di 3 Wii U GamePad Battery Replacement: passo 3, immagine 2 di 3 Wii U GamePad Battery Replacement: passo 3, immagine 3 di 3
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
Conclusione
Altre 24 persone hanno completato questa guida.
USF Tampa, Team 1-6, Sullivan Spring 2016 Membro di USF Tampa, Team 1-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G6
4 Membri
40 Guide realizzate
3 Commenti
I'm trying to put in the new battery, but the connector won't snap in even with larger amounts of force. The original battery, on the other hand, snaps right in.
ToastyGhost - Replica
I have the same issue. The connector on the new battery does not snap in. Does anyone know how to fix this issue and ger the connector to snap into place?
Encom - Replica
It takes a significant amount of pressure (in my opinion) to get the ifixit wii u gamepad battery to snap into place. When I successfully installed this battery, I laid the wii u gamepad screen down with the top of the gamepad facing me. Then I took the flat end of my ifixit spudger, and while pressing down on the battery connector at a 45 degree angle, I pushed the battery connector into the port. You'll be able to tell when the battery is connected all the way. However, this battery does NOT make a snap or click sound to let you know it's connected all the way.
Link to the spudger I used: Spudger
RakmanII -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 15
Ultimi 7 Giorni: 98
Ultimi 30 Giorni: 609
Tutti i Tempi: 12,724
