Salta al contenuto principale
Wii U GamePad Back Panel Replacement
Cosa ti serve
  1. Wii U GamePad Back Panel Replacement, Battery: passo 1, immagine 1 di 2 Wii U GamePad Back Panel Replacement, Battery: passo 1, immagine 2 di 2
    • Face the GamePad down and unscrew the two 4.7 mm Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. Wii U GamePad Back Panel Replacement: passo 2, immagine 1 di 3 Wii U GamePad Back Panel Replacement: passo 2, immagine 2 di 3 Wii U GamePad Back Panel Replacement: passo 2, immagine 3 di 3
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
  3. Wii U GamePad Back Panel Replacement, Back Panel: passo 3, immagine 1 di 3 Wii U GamePad Back Panel Replacement, Back Panel: passo 3, immagine 2 di 3 Wii U GamePad Back Panel Replacement, Back Panel: passo 3, immagine 3 di 3
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
  4. Wii U GamePad Back Panel Replacement: passo 4, immagine 1 di 2 Wii U GamePad Back Panel Replacement: passo 4, immagine 2 di 2
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back panel.
Conclusione
Altre 11 persone hanno completato questa guida.
Kim Arre
Membro da: 01/11/13
5.017 Reputazione
8 Guide realizzate
Cal Poly, Team 17-20, Forte Winter 2013 Membro di Cal Poly, Team 17-20, Forte Winter 2013
CPSU-FORTE-W13S17G20
5 Membri
39 Guide realizzate
2 Commenti
This is either incomplete or mistitled - it is a currently a back plate replacement guide.
At the conclusion of this how-to/walkthrough, most of the GamePad's hardware is still attached to the front plate, one half of the outer case.
Elijah - Replica
and the front?
Raul Kim Diego - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 148
Tutti i Tempi: 15,035
