Salta al contenuto principale
Questa traduzione potrebbe non riflettere gli aggiornamenti più recenti dalla guida originale. Aiuta ad aggiornare la traduzione o visualizza la guida d'origine.
Why! NH57ADS M.2 SSD Replacement
Cosa ti serve
  1. Why! NH57ADS M.2 SSD Replacement, Battery: passo 1, immagine 1 di 3 Why! NH57ADS M.2 SSD Replacement, Battery: passo 1, immagine 2 di 3 Why! NH57ADS M.2 SSD Replacement, Battery: passo 1, immagine 3 di 3
    • Remove the two screws holding the battery in place.
    • Slip your finger into the finger hole provided at the top of the battery and lift to remove it.
  2. Why! NH57ADS M.2 SSD Replacement, Bottom Cover: passo 2, immagine 1 di 3 Why! NH57ADS M.2 SSD Replacement, Bottom Cover: passo 2, immagine 2 di 3 Why! NH57ADS M.2 SSD Replacement, Bottom Cover: passo 2, immagine 3 di 3
    • Remove the five Phillips screws securing the bottom to the case.
    • Slide the cover up slightly to release the catches holding it in place. This is the view on the right. The mark on the cover should now line up with the second mark on the case of the computer.
  3. Why! NH57ADS M.2 SSD Replacement, Removing the Bottom Cover: passo 3, immagine 1 di 3 Why! NH57ADS M.2 SSD Replacement, Removing the Bottom Cover: passo 3, immagine 2 di 3 Why! NH57ADS M.2 SSD Replacement, Removing the Bottom Cover: passo 3, immagine 3 di 3
    • This is the view on the left before and after sliding the cover. The mark on the cover should now line up with the second mark on the case of the computer.
    • Lift the bottom cover to remove it.
  4. Why! NH57ADS M.2 SSD Replacement, Remove the M.2 SSD: passo 4, immagine 1 di 2 Why! NH57ADS M.2 SSD Replacement, Remove the M.2 SSD: passo 4, immagine 2 di 2
    • Remove the Phillips screw securing the M.2 SSD drive in place. The end of the drive will pop up by a small amount.
    • Slide the drive out from the connector in a straight line. If you feel resistance, try raising it slightly.
Conclusione
To reassemble your device, follow the instructions in reverse order.
Un ringraziamento speciale a questi traduttori:
fr en
80%
Jerry Wheeler ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Felice Suglia
Membro da: 06/15/13
33.538 Reputazione
283 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 330
