Salta al contenuto principale
Whirlpool Refrigerator Water Inlet Valve Replacement
Cosa ti serve
  1. Whirlpool Refrigerator Water Inlet Valve Replacement, Safety precautions: passo 1, immagine 1 di 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: passo 2, immagine 1 di 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: passo 2, immagine 2 di 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: passo 2, immagine 3 di 3
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  3. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: passo 3, immagine 1 di 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: passo 3, immagine 2 di 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: passo 3, immagine 3 di 3
    • Pull the rear panel off the chassis to remove it.
  4. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: passo 4, immagine 1 di 2 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: passo 4, immagine 2 di 2
    • Use needle nose pliers, or your fingers, to remove the plastic clip on the inlet valve assembly.
  5. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: passo 5, immagine 1 di 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: passo 5, immagine 2 di 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: passo 5, immagine 3 di 3
    • Push the plastic ring above the front water hose to release its clips.
    • As you push the ring, pull the water hose downward to disconnect it.
    • Repeat the disconnection procedure for the other water hose on the inlet valve assembly.
  6. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the inlet valve assembly: passo 6, immagine 1 di 1
    • Remove the screw(s) securing the inlet valve assembly.
  7. Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: passo 7, immagine 1 di 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: passo 7, immagine 2 di 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: passo 7, immagine 3 di 3
    • Pull the inlet valve assembly off its slot in the chassis and rest it on the floor.
  8. Whirlpool Refrigerator Water Inlet Valve Replacement: passo 8, immagine 1 di 2 Whirlpool Refrigerator Water Inlet Valve Replacement: passo 8, immagine 2 di 2
    • Place a clean and dry rag under the inlet valve assembly before continuing.
  9. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: passo 9, immagine 1 di 2 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: passo 9, immagine 2 di 2
    • Use needle nose pliers, or your hands, to pull the clip off the rear water hose.
  10. Whirlpool Refrigerator Water Inlet Valve Replacement: passo 10, immagine 1 di 3 Whirlpool Refrigerator Water Inlet Valve Replacement: passo 10, immagine 2 di 3 Whirlpool Refrigerator Water Inlet Valve Replacement: passo 10, immagine 3 di 3
    • Push the yellow plastic ring above the rear water hose to release its clips.
    • As you push the ring, pull the water hose away from the inlet valve assembly to disconnect it.
  11. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: passo 11, immagine 1 di 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: passo 11, immagine 2 di 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: passo 11, immagine 3 di 3
    • Use a flathead screwdriver, or a similar tool, to disconnect any wire connectors attached to the inlet valve assembly.
  12. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the inlet valve assembly: passo 12, immagine 1 di 1
    • Remove the inlet valve assembly from the chassis.
  13. Whirlpool Refrigerator Water Inlet Valve Replacement, Meter the inlet valve assembly: passo 13, immagine 1 di 1
    • If you own a multimeter, you can test your inlet valve assembly's resistance.
    • A range between 500–1.5 kΩ is acceptable.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro da: 04/14/15
15.876 Reputazione
88 Guide realizzate
Global Fixers Membro di Global Fixers
Community
29 Membri
466 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 69
Ultimi 30 Giorni: 262
Tutti i Tempi: 1,606
