Salta al contenuto principale
Whirlpool Refrigerator Freezer Thermistor Replacement
Cosa ti serve
  1. Whirlpool Refrigerator Freezer Thermistor Replacement, Safety precautions: passo 1, immagine 1 di 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: passo 2, immagine 1 di 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: passo 2, immagine 2 di 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: passo 2, immagine 3 di 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: passo 3, immagine 1 di 2 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: passo 3, immagine 2 di 2
    • Remove the drawers and shelves from the freezer section.
  4. Whirlpool Refrigerator Freezer Thermistor Replacement: passo 4, immagine 1 di 2 Whirlpool Refrigerator Freezer Thermistor Replacement: passo 4, immagine 2 di 2
    • Remove the screw(s) securing the evaporator cover.
  5. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: passo 5, immagine 1 di 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: passo 5, immagine 2 di 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: passo 5, immagine 3 di 3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: passo 6, immagine 1 di 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: passo 6, immagine 2 di 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: passo 6, immagine 3 di 3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: passo 7, immagine 1 di 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: passo 7, immagine 2 di 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: passo 7, immagine 3 di 3
    • Use a spudger to push the tip of the thermistor through its slot in the wire harness.
  8. Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: passo 8, immagine 1 di 2 Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: passo 8, immagine 2 di 2
    • Disconnect any connectors attached to the thermistor.
  9. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the thermistor: passo 9, immagine 1 di 1
    • Remove the thermistor.
  10. Whirlpool Refrigerator Freezer Thermistor Replacement, Meter the thermistor: passo 10, immagine 1 di 1
    • If you own a multimeter, you can test your thermistor's resistance.
    • A range between 2-220KΩ is acceptable. Check the specifications for your specific thermistor since there is such a large variance, and make sure you test at the appropriate temperature.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro da: 04/14/15
15.876 Reputazione
88 Guide realizzate
Global Fixers Membro di Global Fixers
Community
29 Membri
466 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 115
Tutti i Tempi: 919
