Salta al contenuto principale
Whirlpool Refrigerator Drain Pan Replacement
Cosa ti serve
  1. Whirlpool Refrigerator Drain Pan Replacement, Safety precautions: passo 1, immagine 1 di 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Drain Pan Replacement, Open the doors: passo 2, immagine 1 di 3 Whirlpool Refrigerator Drain Pan Replacement, Open the doors: passo 2, immagine 2 di 3 Whirlpool Refrigerator Drain Pan Replacement, Open the doors: passo 2, immagine 3 di 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Drain Pan Replacement, Unfasten the front panel: passo 3, immagine 1 di 3 Whirlpool Refrigerator Drain Pan Replacement, Unfasten the front panel: passo 3, immagine 2 di 3 Whirlpool Refrigerator Drain Pan Replacement, Unfasten the front panel: passo 3, immagine 3 di 3
    • Remove the screw(s) securing the front panel.
  4. Whirlpool Refrigerator Drain Pan Replacement, Remove the front panel: passo 4, immagine 1 di 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the front panel: passo 4, immagine 2 di 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the front panel: passo 4, immagine 3 di 3
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. Whirlpool Refrigerator Drain Pan Replacement, Unfasten the wiring harness: passo 5, immagine 1 di 1
    • Use a 1/4 inch socket wrench to remove the 16.7 mm-long screw securing the wiring harness.
  6. Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: passo 6, immagine 1 di 2 Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: passo 6, immagine 2 di 2
    • Pull the wiring harness out of its slot in the chassis to access its connectors.
  7. Whirlpool Refrigerator Drain Pan Replacement, Disconnect the wiring harness: passo 7, immagine 1 di 3 Whirlpool Refrigerator Drain Pan Replacement, Disconnect the wiring harness: passo 7, immagine 2 di 3 Whirlpool Refrigerator Drain Pan Replacement, Disconnect the wiring harness: passo 7, immagine 3 di 3
    • Disconnect the two connectors attached to the door wiring harness.
  8. Whirlpool Refrigerator Drain Pan Replacement, Unfasten the rear panel: passo 8, immagine 1 di 3 Whirlpool Refrigerator Drain Pan Replacement, Unfasten the rear panel: passo 8, immagine 2 di 3 Whirlpool Refrigerator Drain Pan Replacement, Unfasten the rear panel: passo 8, immagine 3 di 3
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  9. Whirlpool Refrigerator Drain Pan Replacement, Remove the rear panel: passo 9, immagine 1 di 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the rear panel: passo 9, immagine 2 di 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the rear panel: passo 9, immagine 3 di 3
    • Pull the rear panel off the chassis to remove it.
  10. Whirlpool Refrigerator Drain Pan Replacement, Remove the condenser fan: passo 10, immagine 1 di 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the condenser fan: passo 10, immagine 2 di 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the condenser fan: passo 10, immagine 3 di 3
    • Put on gloves before continuing, as the sheet metal and the condenser fan itself are sharp.
    • Pull the condenser fan straight off its peg to remove it.
  11. Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: passo 11, immagine 1 di 2 Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: passo 11, immagine 2 di 2
    • Use a flathead screwdriver, or a similar tool, to pry up the metal clip from the back of the drain pan.
  12. Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: passo 12, immagine 1 di 3 Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: passo 12, immagine 2 di 3 Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: passo 12, immagine 3 di 3
    • Pull the wiring harness straight out of the chassis until you can access the drain pan.
  13. Whirlpool Refrigerator Drain Pan Replacement, Peel the tape: passo 13, immagine 1 di 3 Whirlpool Refrigerator Drain Pan Replacement, Peel the tape: passo 13, immagine 2 di 3 Whirlpool Refrigerator Drain Pan Replacement, Peel the tape: passo 13, immagine 3 di 3
    • Peel the tape off the front metal clip attached to the drain pan.
  14. Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: passo 14, immagine 1 di 3 Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: passo 14, immagine 2 di 3 Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: passo 14, immagine 3 di 3
    • Use your fingers to release the metal clip on the front of the drain pan.
    • Fold the metal clip so that it lays flat on the floor of the chassis.
  15. Whirlpool Refrigerator Drain Pan Replacement, Remove the drain pan: passo 15, immagine 1 di 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the drain pan: passo 15, immagine 2 di 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the drain pan: passo 15, immagine 3 di 3
    • Pull the drain pan toward the front of the chassis to release any remaining clips.
    • Remove the drain pan.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro da: 04/14/15
15.876 Reputazione
88 Guide realizzate
Global Fixers Membro di Global Fixers
Community
29 Membri
465 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 40
Ultimi 30 Giorni: 205
Tutti i Tempi: 1,875
