Salta al contenuto principale
Whirlpool Refrigerator Door Sensor Replacement
Cosa ti serve
  1. Whirlpool Refrigerator Door Sensor Replacement, Open the doors: passo 1, immagine 1 di 3 Whirlpool Refrigerator Door Sensor Replacement, Open the doors: passo 1, immagine 2 di 3 Whirlpool Refrigerator Door Sensor Replacement, Open the doors: passo 1, immagine 3 di 3
    • Depending on your repair, open one or both doors.
  2. Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: passo 2, immagine 1 di 3 Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: passo 2, immagine 2 di 3 Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: passo 2, immagine 3 di 3
    • Insert a flathead screwdriver, or a similar tool, between the door sensor and the chassis.
    • Pry up to separate the door sensor enough so you can grip it with your fingers.
  3. Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: passo 3, immagine 1 di 2 Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: passo 3, immagine 2 di 2
    • Pull the door sensor through the chassis enough to access its connectors.
    • Disconnect any connectors attached to the door sensor.
    • Remove the door sensor.
  4. Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: passo 4, immagine 1 di 2 Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: passo 4, immagine 2 di 2
    • If you own a multimeter, you can test your door sensor's resistance.
    • Set the multimeter to the resistance or continuity measurement mode.
    • With the button in its neutral position, the multimeter should read "OL."
    • With the button pressed, the multimeter should read around 0Ω.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro da: 04/14/15
15.876 Reputazione
88 Guide realizzate
Global Fixers Membro di Global Fixers
Community
29 Membri
466 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 148
Tutti i Tempi: 1,041
