Salta al contenuto principale
Whirlpool Refrigerator Condenser Fan Replacement
Cosa ti serve
  1. Whirlpool Refrigerator Condenser Fan Replacement, Safety precautions: passo 1, immagine 1 di 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: passo 2, immagine 1 di 3 Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: passo 2, immagine 2 di 3 Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: passo 2, immagine 3 di 3
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  3. Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: passo 3, immagine 1 di 3 Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: passo 3, immagine 2 di 3 Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: passo 3, immagine 3 di 3
    • Pull the rear panel off the chassis to remove it.
  4. Whirlpool Refrigerator Condenser Fan Replacement, Disconnect the condenser fan: passo 4, immagine 1 di 2 Whirlpool Refrigerator Condenser Fan Replacement, Disconnect the condenser fan: passo 4, immagine 2 di 2
    • Disconnect the connector attached to the condenser fan.
  5. Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: passo 5, immagine 1 di 3 Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: passo 5, immagine 2 di 3 Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: passo 5, immagine 3 di 3
    • Put on gloves before continuing, as the sheet metal and the fan itself are sharp.
    • Pull the condenser fan straight off its peg to remove it.
  6. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the condenser fan motor: passo 6, immagine 1 di 1
    • Remove the screw(s) securing the condenser fan motor to the chassis.
  7. Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: passo 7, immagine 1 di 3 Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: passo 7, immagine 2 di 3 Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: passo 7, immagine 3 di 3
    • Rotate the motor housing through its slot in the chassis.
    • Remove the motor.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
Altre 3 persone hanno completato questa guida.
nicO
Membro da: 04/14/15
15.876 Reputazione
88 Guide realizzate
Global Fixers Membro di Global Fixers
Community
29 Membri
466 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 89
Tutti i Tempi: 754
