Salta al contenuto principale
Whirlpool Electric Range Oven Light Replacement
Cosa ti serve
  1. Whirlpool Electric Range Oven Light Replacement, Oven Light: passo 1, immagine 1 di 1
    • Disconnect the oven from the power source.
    • Not removing the plug from the power could cause injuries or be fatal.
  2. Whirlpool Electric Range Oven Light Replacement: passo 2, immagine 1 di 1
    • Remove the oven racks for better movement.
  3. Whirlpool Electric Range Oven Light Replacement: passo 3, immagine 1 di 1
    • Remove the glass bulb covering by rotating it counterclockwise.
    • The bulb coverings look like little jars. There may be multiple bulbs in the back or side of the oven.
  4. Whirlpool Electric Range Oven Light Replacement: passo 4, immagine 1 di 1
    • Unscrew the bulb in a counterclockwise manner.
  5. Whirlpool Electric Range Oven Light Replacement: passo 5, immagine 1 di 1
    • Insert the new bulb in by rotating it in a clockwise manner.
  6. Whirlpool Electric Range Oven Light Replacement: passo 6, immagine 1 di 1
    • Screw the glass bulb covering back on in a clockwise manner.
  7. Whirlpool Electric Range Oven Light Replacement: passo 7, immagine 1 di 1
    • Reinsert the oven racks.
  8. Whirlpool Electric Range Oven Light Replacement: passo 8, immagine 1 di 1
    • Plug the outlet back in to the power source.
Linea Traguardo
Kevin Patel
Membro da: 03/23/21
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 63
Tutti i Tempi: 3,376
