Salta al contenuto principale
Whirlpool Duet Steam Washer Drain Pump Replacement
Cosa ti serve
  1. Whirlpool Duet Steam Washer Drain Pump Replacement, Drain Pump: passo 1, immagine 1 di 1
    • For your own safety, be sure to unplug the washer before proceeding.
    Chiedi a FixBot
    Aggiungi Commento
  2. Whirlpool Duet Steam Washer Drain Pump Replacement: passo 2, immagine 1 di 1
    • To ensure that no more water passes through the washer, shut off the water by turning both handles all the way to the left.
    Chiedi a FixBot
    Aggiungi Commento
  3. Whirlpool Duet Steam Washer Drain Pump Replacement: passo 3, immagine 1 di 3 Whirlpool Duet Steam Washer Drain Pump Replacement: passo 3, immagine 2 di 3 Whirlpool Duet Steam Washer Drain Pump Replacement: passo 3, immagine 3 di 3
    • Use a 1/4" socket or screwdriver to remove the sixteen 15 mm screws securing the rear access panel.
    • Remember: turn left to loosen and turn right to tighten!
    • Remove the rear access panel.
    Chiedi a FixBot
    Aggiungi Commento
  4. Whirlpool Duet Steam Washer Drain Pump Replacement: passo 4, immagine 1 di 1
    • Pull the drain pump wire connector straight out of its port.
    Chiedi a FixBot
    Aggiungi Commento
  5. Whirlpool Duet Steam Washer Drain Pump Replacement: passo 5, immagine 1 di 2 Whirlpool Duet Steam Washer Drain Pump Replacement: passo 5, immagine 2 di 2
    • Place your bowl or container under the drain hose before removal to catch any excess water that may be in the hose.
    • Use pliers to release the clamps securing the drain hose to the drain pump.
    • Pull the drain pump out.
    Chiedi a FixBot
    Aggiungi Commento
  6. Whirlpool Duet Steam Washer Drain Pump Replacement: passo 6, immagine 1 di 2 Whirlpool Duet Steam Washer Drain Pump Replacement: passo 6, immagine 2 di 2
    • Use a 5/16" socket to remove the two 50 mm drain pump mounting screws.
    • There is one screw on each side of the pump.
    • Pull the drain pump down to remove it.
    • If it is difficult to remove, you can wiggle the pump in a side-to-side motion until it releases.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Edgar Ibarra
Membro da: 03/15/22
133 Reputazione
Una guida realizzata
UM-KIM-S22SMG3 Membro di UM-KIM-S22SMG3
Local Repair Groups
4 Membri
2 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 42
Ultimi 30 giorni: 208
Tutti i Tempi: 9,411
