Salta al contenuto principale
Wexford CT-166TF Air Filter Casing Replacement
Cosa ti serve
  1. Wexford CT-166TF Air Filter Casing Replacement, Air Filter Casing: passo 1, immagine 1 di 1
    • Using a plastic opening tool, remove the four small foam pieces on the bottom of the fan.
  2. Wexford CT-166TF Air Filter Casing Replacement: passo 2, immagine 1 di 3 Wexford CT-166TF Air Filter Casing Replacement: passo 2, immagine 2 di 3 Wexford CT-166TF Air Filter Casing Replacement: passo 2, immagine 3 di 3
    • Remove the four screws that were uncovered in the previous step.
    • Remove the bottom cover using a spudger if needed.
  3. Wexford CT-166TF Air Filter Casing Replacement: passo 3, immagine 1 di 1
    • Remove the five screws that can be seen by aligning the base and the fan.
  4. Wexford CT-166TF Air Filter Casing Replacement: passo 4, immagine 1 di 2 Wexford CT-166TF Air Filter Casing Replacement: passo 4, immagine 2 di 2
    • Stand the fan upright. Locate and remove the two screws near the top.
  5. Wexford CT-166TF Air Filter Casing Replacement: passo 5, immagine 1 di 2 Wexford CT-166TF Air Filter Casing Replacement: passo 5, immagine 2 di 2
    • Locate and remove the two bottom screws.
  6. Wexford CT-166TF Air Filter Casing Replacement: passo 6, immagine 1 di 1
    • Remove the back casing by pulling it away from the front casing.
  7. Wexford CT-166TF Air Filter Casing Replacement: passo 7, immagine 1 di 2 Wexford CT-166TF Air Filter Casing Replacement: passo 7, immagine 2 di 2
    • Remove the two screws attaching the motor to the front casing.
  8. Wexford CT-166TF Air Filter Casing Replacement: passo 8, immagine 1 di 2 Wexford CT-166TF Air Filter Casing Replacement: passo 8, immagine 2 di 2
    • Remove the two middle screws connecting the air filter casing to the front casing.
    • Remove the front casing.
  9. Wexford CT-166TF Air Filter Casing Replacement: passo 9, immagine 1 di 1
    • Remove the four remain screws holding the air filter casing together
  10. Wexford CT-166TF Air Filter Casing Replacement: passo 10, immagine 1 di 2 Wexford CT-166TF Air Filter Casing Replacement: passo 10, immagine 2 di 2
    • Put the new air filter casing in place after cleaning the filter.
    • Repeat steps 1-9 in reverse order to properly put back together the fan.
Conclusione
UW Tacoma, Team S3-G4, Liner Spring 2017 Membro di UW Tacoma, Team S3-G4, Liner Spring 2017
UWT-LINER-S17S3G4
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 634
