Salta al contenuto principale
Western Digital My Book Mini USB Port Replacement
Cosa ti serve
  1. Western Digital My Book Mini USB Port Replacement, Mini USB Port: passo 1, immagine 1 di 3 Western Digital My Book Mini USB Port Replacement, Mini USB Port: passo 1, immagine 2 di 3 Western Digital My Book Mini USB Port Replacement, Mini USB Port: passo 1, immagine 3 di 3
    • Start by turning the device port side up.
    • With the plastic opening tool, pry along the edges of the case.
    • When you hear the case snap-out of its fitted grooves, slowly slide the board assembly out of the case.
    Chiedi a FixBot
  2. Western Digital My Book Mini USB Port Replacement: passo 2, immagine 1 di 1
    • Gently pull the three pronged, clear plastic piece from the rubber holder.
    Chiedi a FixBot
  3. Western Digital My Book Mini USB Port Replacement: passo 3, immagine 1 di 1
    • Unscrew the two screws from the motherboard.
    Chiedi a FixBot
  4. Western Digital My Book Mini USB Port Replacement: passo 4, immagine 1 di 1
    • Remove all the rubber pieces from the four corners to unhinge the motherboard.
    Chiedi a FixBot
  5. Western Digital My Book Mini USB Port Replacement: passo 5, immagine 1 di 1
    • Remove the motherboard.
    • Set aside in a safe anti-static location.
    Chiedi a FixBot
  6. Western Digital My Book Mini USB Port Replacement: passo 6, immagine 1 di 1
    • Grab the mini USB port and align it with the appropriate metal docks on the motherboard.
    Chiedi a FixBot
  7. Western Digital My Book Mini USB Port Replacement: passo 7, immagine 1 di 1
    • Soldering irons can get HOT! Do not touch the iron tip, make sure it cools down for a good 30 minutes before touching the tip.
    • Start heating up the Soldering Iron, may take about 10–15 mins.
    Chiedi a FixBot
  8. Western Digital My Book Mini USB Port Replacement: passo 8, immagine 1 di 1
    • Solder together the four corners of the mini USB to the appropriate metal pieces on the motherboard.
    • Make sure the USB is firmly attached to the motherboard.
    Chiedi a FixBot
Conclusione
To reassemble your device, follow these instructions in reverse order from step 8.
Altre 8 persone hanno completato questa guida.
Gabriel Rael
Membro da: 06/24/15
333 Reputazione
Una guida realizzata
Colorado Springs, Team 1-2, Mcmichael SU 2015 Membro di Colorado Springs, Team 1-2, Mcmichael SU 2015
UCCS-MCMICHAEL-SU15S1G2
2 Membri
2 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 26
Ultimi 30 giorni: 133
Tutti i Tempi: 18,524
