Salta al contenuto principale
Wen 2307 Speed Adjustment Assembly Replacement
Cosa ti serve
  1. Wen 2307 Speed Adjustment Assembly Replacement, Front Panel: passo 1, immagine 1 di 1
    • Unscrew the locking sleeve.
  2. Wen 2307 Speed Adjustment Assembly Replacement: passo 2, immagine 1 di 1
    • Remove the hanging clip.
  3. Wen 2307 Speed Adjustment Assembly Replacement: passo 3, immagine 1 di 2 Wen 2307 Speed Adjustment Assembly Replacement: passo 3, immagine 2 di 2
    • Unscrew the six 8mm PH2 screws.
  4. Wen 2307 Speed Adjustment Assembly Replacement: passo 4, immagine 1 di 1
    • While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
  5. Wen 2307 Speed Adjustment Assembly Replacement: passo 5, immagine 1 di 1
    • To remove the front panel, pry the device apart while holding the device with the other hand.
    • The front panel should come out easily.
  6. Wen 2307 Speed Adjustment Assembly Replacement, Power Cable: passo 6, immagine 1 di 2 Wen 2307 Speed Adjustment Assembly Replacement, Power Cable: passo 6, immagine 2 di 2
    • Identify the screws.
    • Unscrew the two 3mm phillips PH2.
    • Don't forget to put them appart from the ones unscrewed before.
    • Phillips PH2
    • Flathead 2.5mm
  7. Wen 2307 Speed Adjustment Assembly Replacement: passo 7, immagine 1 di 1
    • Remove the place boar carefully.
  8. Wen 2307 Speed Adjustment Assembly Replacement: passo 8, immagine 1 di 1
    • Pull out the power cable connectors.
  9. Wen 2307 Speed Adjustment Assembly Replacement: passo 9, immagine 1 di 1
    • Pull out the cord sleve for the new cable replacement.
  10. Wen 2307 Speed Adjustment Assembly Replacement, Speed Adjustment Assembly: passo 10, immagine 1 di 1
    • Remove the connected wiring from the circuit board.
  11. Wen 2307 Speed Adjustment Assembly Replacement: passo 11, immagine 1 di 1
    • Remove the single 4mm screw retaining the circuit board.
  12. Wen 2307 Speed Adjustment Assembly Replacement: passo 12, immagine 1 di 1
    • Gently pry the circuit board from the back piece.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 12-1, Eyestone Spring 2016 Membro di USF Tampa, Team 12-1, Eyestone Spring 2016
USFT-EYESTONE-S16S12G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 757
