Salta al contenuto principale
Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement
Cosa ti serve
  1. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement, Stand: passo 1, immagine 1 di 2 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement, Stand: passo 1, immagine 2 di 2
    • Unplug the AC power connection cable.
  2. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 2, immagine 1 di 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 2, immagine 2 di 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 2, immagine 3 di 3
    • Place your thumb and forefinger on the blood pressure (NIBP) hose connector. Squeeze the side tabs until the connector releases.
    • Always grasp the hose by the connector. Do not pull on the hose itself.
    • Pull the connector away from the connector port.
  3. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 3, immagine 1 di 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 3, immagine 2 di 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 3, immagine 3 di 3
    • Place your thumb and forefinger on the Pulse oximetry (SpO2 or combined SpO2/SpHb) cable connector. Squeeze the side tabs until the connector releases.
    • Always grasp the cable by the connector. Do not pull on the cable itself.
  4. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 4, immagine 1 di 2 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 4, immagine 2 di 2
    • Grasp the temperature probe and pull it up to remove it from the monitor.
  5. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 5, immagine 1 di 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 5, immagine 2 di 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 5, immagine 3 di 3
    • Remove the cover of the temperature module by pressing the tab and sliding the cover to the right.
  6. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 6, immagine 1 di 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 6, immagine 2 di 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 6, immagine 3 di 3
    • Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port.
  7. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 7, immagine 1 di 1
    • Remove the flathead screw on the USB networking door.
    • Loosen the captive Phillips #2 screw securing the monitor to the stand.
  8. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 8, immagine 1 di 1
    • Holding the monitor securely, open the USB networking door.
    • You may have to lift the monitor slightly to allow the door to swing out from the stand mount.
  9. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 9, immagine 1 di 2 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 9, immagine 2 di 2
    • Detach any accessory USB cables from USB ports on the monitor.
  10. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 10, immagine 1 di 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 10, immagine 2 di 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 10, immagine 3 di 3
    • Slide the monitor off of the stand tray.
Conclusione
Sam Goldheart
Membro da: 10/18/12
465.777 Reputazione
538 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 864
