Introduzione
The sealing is situated between tank and machine. You can easily see if it´s not watertight.
Cosa ti serve
The instructions are suitable for nearly every model of Jura and similar ones e.g. AEG and Krups.
Remove the water reservoir.
Using an oval head bit you can screw them out. If you haven´t got one you can carefully use pliers. It is a good idea to later change the screws for normal ones.
Beneath both top side covers are two Torx T15 screws. Remove those. Now lift off the whole top cover. Sometimes it jams and you have to use a bit of force.
The side covers must be pushed backwards by about 1 cm. Sometimes this is a little bit difficult to move. If necessary, wedge a plastic opening tool into the gap between the side covers and the front panel. The rear cover can be easily removed.
The support of the sealing is secured by a screw, mostly Tx 15.
On the left and right side are notches, open them and raise the support.
Turn it upside down.
Press both plastic rivets with tiers, then push them out. The cover of the sealing is free.
Change sealings. The old one was black, the new one red.
Attach cover
Now follow the steps in reverse direction.
Altre 4 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
VauWeh ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
