Introduzione
This guide will show you how to refill the dancing water speakers through the bottom water plug. These water speakers have a tendency to leak through the bottom water plug. This guide will show you step-by-step how to take the speakers apart so you can replace the water plug with super glue. The reason why we replace it with super glue is the glue works to seal the hole a lot more effectively and it's a simple process.
Strumenti
Parti
Nessuna parte specificata.
You will need to have a clean work space, water dancing speakers, super glue, mineral water, and Phillips screw driver ready.
On the bottom of the water canister you will see a hole where the water was inserted. There will be a black plug covering the hole.
Using your screw driver you can pry the plug out.
Once the plug is taken out you can refill the speakers. Only refill the speakers with one inch of water.
Your water dancing speakers are now ready for use. Thank you for using this guide.
Altre 40 persone hanno completato questa guida.
32 Commenti
the pump is defective how to replace
anpicard@videotron.ca
I couldnt get plug out either so I drilled a hole in back and filled it with mineral water and sealed it with a small strip of scotch tape and duct tape on top of that in case I had to get back in. It works, but now it looks different. Sometimes the water clings to the inside and it looks a little foggy. Is it mineral water, or mineral oil? If it leaks again I'll prob try the oil.
The original liquid has a lower surface tension than water. I used odorless mineral spirits.
If the pump is noisy, try a drop of oil in the motor.
good it worked with me, thanks for guidance.
