Salta al contenuto principale
Water Damage on main board of Nokia 206 RM873
Cosa ti serve
  1. Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: passo 1, immagine 1 di 3 Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: passo 1, immagine 2 di 3 Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: passo 1, immagine 3 di 3
    • Remove back cover & battery.
  2. Water Damage on main board of Nokia 206 RM873: passo 2, immagine 1 di 2 Water Damage on main board of Nokia 206 RM873: passo 2, immagine 2 di 2
    • Remove the front case by prying it open. You will hear clicks.
    • Be careful with taking off screen if you use a spudger.
  3. Water Damage on main board of Nokia 206 RM873: passo 3, immagine 1 di 2 Water Damage on main board of Nokia 206 RM873: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a Torx screwdriver to remove the screen screws.
    • Use a spudger or tweezers to remove the connector of the LCD screen.
  4. Water Damage on main board of Nokia 206 RM873: passo 4, immagine 1 di 3 Water Damage on main board of Nokia 206 RM873: passo 4, immagine 2 di 3 Water Damage on main board of Nokia 206 RM873: passo 4, immagine 3 di 3
    • The PCB board had water damage, see this in picture 3.
    • To remove the corrosion, dab a cotton swab with a little distilled water on the corroded area, the corrosion will disappear.
  5. Water Damage on main board of Nokia 206 RM873: passo 5, immagine 1 di 2 Water Damage on main board of Nokia 206 RM873: passo 5, immagine 2 di 2
    • How and where to use the cotton swabs.
Conclusione
Altre 17 persone hanno completato questa guida.
Kevin D
Membro da: 05/02/14
7.343 Reputazione
21 Guide realizzate
4 Commenti
no use .it is not switching on . replaced with good batter also. no on
nabhan75 - Replica
try to clean with an ultrasonic bath.
measure out powerrail.
measure out the voltage coming in on board. try to see if you have short.
Kevin D - Replica
Nokia 206 display and charger pin
Mithilesh Yadav - Replica
Not working kiy 1.2.3 and colling ricev kiy not working
K .M Jugesh - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 30
Tutti i Tempi: 10,871
