Salta al contenuto principale
Waring Pro SB30 Plastic Sides Replacement
Cosa ti serve
  1. Waring Pro SB30 Plastic Sides Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
    • The screws in the rubber legs of the burner do not need to be removed.
    • If the back panel has never been opened before, the screws may be more difficult to unscrew.
  2. Waring Pro SB30 Plastic Sides Replacement: passo 2, immagine 1 di 2 Waring Pro SB30 Plastic Sides Replacement: passo 2, immagine 2 di 2
    • Using a wrench, remove the bolt from the center of the back panel.
  3. Waring Pro SB30 Plastic Sides Replacement: passo 3, immagine 1 di 1
    • The back panel can now be easily lifted off.
  4. Waring Pro SB30 Plastic Sides Replacement, Plastic Sides: passo 4, immagine 1 di 2 Waring Pro SB30 Plastic Sides Replacement, Plastic Sides: passo 4, immagine 2 di 2
    • Using a #1 Phillips screwdriver bit or a ratchet wrench with a Phillips screwdriver bit to remove screws located on the interior frame.
    • The interior edges of the metal frame are sharp and can cause minor cuts.
  5. Waring Pro SB30 Plastic Sides Replacement: passo 5, immagine 1 di 1
    • Plastic sides should be easily removed after all screws are taken out.
Conclusione
Sun Fai Lau
Membro da: 09/22/14
588 Reputazione
5 Guide realizzate
USF Tampa, Team 10-7, Brown Fall 2014 Membro di USF Tampa, Team 10-7, Brown Fall 2014
USFT-BROWN-F14S10G7
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 244
