Introduzione
The plastic sides can become damaged, melted or warped when using a pot larger than the burner. So be sure to remove the back panel first before pulling these sides off.
The screws are located along the interior sides of the metal frame, so consider wearing gloves when removing the screws to avoid cuts from the sharp edges.
Parti
Nessuna parte richiesta.
Remove the screws on the back panel with the #1 Phillips screwdriver bit.
  • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
    • The screws in the rubber legs of the burner do not need to be removed.
    • If the back panel has never been opened before, the screws may be more difficult to unscrew.
Aggiungi Commento
Using a wrench, remove the bolt from the center of the back panel.
  • Using a wrench, remove the bolt from the center of the back panel.
Aggiungi Commento
  • The back panel can now be easily lifted off.
Aggiungi Commento
  • Using a #1 Phillips screwdriver bit or a ratchet wrench with a Phillips screwdriver bit to remove screws located on the interior frame.
    • The interior edges of the metal frame are sharp and can cause minor cuts.
Aggiungi Commento
  • Plastic sides should be easily removed after all screws are taken out.
Aggiungi Commento
Conclusione
Sun Fai Lau
Membro da: 22/09/2014
513 Reputazione
5 Guide realizzate
USF Tampa, Team 10-7, Brown Fall 2014 Membro di USF Tampa, Team 10-7, Brown Fall 2014
USFT-BROWN-F14S10G7
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 107
