Salta al contenuto principale
Waring Pro SB30 Indicator Lights Replacement
Cosa ti serve
  1. Waring Pro SB30 Indicator Lights Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
    • The screws in the rubber legs of the burner do not need to be removed.
    • If the back panel has never been opened before, the screws may be more difficult to unscrew.
  2. Waring Pro SB30 Indicator Lights Replacement: passo 2, immagine 1 di 2 Waring Pro SB30 Indicator Lights Replacement: passo 2, immagine 2 di 2
    • Using a wrench, remove the bolt from the center of the back panel.
  3. Waring Pro SB30 Indicator Lights Replacement: passo 3, immagine 1 di 1
    • The back panel can now be easily lifted off.
  4. Waring Pro SB30 Indicator Lights Replacement, Indicator Lights: passo 4, immagine 1 di 1
    • Using two thin screwdrivers (or similar objects) wedge them into the slots of the plastic shell of the desired light.
  5. Waring Pro SB30 Indicator Lights Replacement: passo 5, immagine 1 di 2 Waring Pro SB30 Indicator Lights Replacement: passo 5, immagine 2 di 2
    • Push the screwdrivers inward and guide the bulb outwards.
    • Gently grab by the wires and remove bulb from plastic shell.
Conclusione
Sun Fai Lau
Membro da: 09/22/14
588 Reputazione
5 Guide realizzate
USF Tampa, Team 10-7, Brown Fall 2014 Membro di USF Tampa, Team 10-7, Brown Fall 2014
USFT-BROWN-F14S10G7
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 315
