Salta al contenuto principale
Waring 51BL29 Switch Replacement
Cosa ti serve
  1. Waring 51BL29 Switch Replacement, Bottom Panel: passo 1, immagine 1 di 2 Waring 51BL29 Switch Replacement, Bottom Panel: passo 1, immagine 2 di 2
    • Turn the blender on its side so the bottom panel is facing you.
    • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
    • Unscrew the 3 screws in the rubber holes.
  2. Waring 51BL29 Switch Replacement: passo 2, immagine 1 di 1
    • Remove the bottom panel.
  3. Waring 51BL29 Switch Replacement, Drive Coupling: passo 3, immagine 1 di 1
    • Place the screwdriver in the head of the middle flat-head screw.
  4. Waring 51BL29 Switch Replacement: passo 4, immagine 1 di 1
    • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
    • This screw may be reverse-threaded.
  5. Waring 51BL29 Switch Replacement: passo 5, immagine 1 di 1
    • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
  6. Waring 51BL29 Switch Replacement, Motor: passo 6, immagine 1 di 2 Waring 51BL29 Switch Replacement, Motor: passo 6, immagine 2 di 2
    • Unscrew the four nuts in the bottom of the motor cavity.
    • Wiggle the motor until it is free and you can remove it.
  7. Waring 51BL29 Switch Replacement: passo 7, immagine 1 di 1
    • Once motor is pulled out, unscrew the 8 mm screw for the green wire from the base of the blender.
  8. Waring 51BL29 Switch Replacement: passo 8, immagine 1 di 3 Waring 51BL29 Switch Replacement: passo 8, immagine 2 di 3 Waring 51BL29 Switch Replacement: passo 8, immagine 3 di 3
    • Unscrew each white wire cap in order to free the motor from the power cord.
    • Once wire caps are removed, separate wires carefully.
  9. Waring 51BL29 Switch Replacement, Switch: passo 9, immagine 1 di 1
    • Once you have the motor and switch by themselves it should look like this.
  10. Waring 51BL29 Switch Replacement: passo 10, immagine 1 di 2 Waring 51BL29 Switch Replacement: passo 10, immagine 2 di 2
    • Separate the zip-tie holding the wires to the motor.
  11. Waring 51BL29 Switch Replacement: passo 11, immagine 1 di 1
    • Now the switch is separated from the motor and blender frame.
Conclusione
Dean Becker
Membro da: 04/17/17
470 Reputazione
4 Guide realizzate
Cal Poly, Team S15-G4, Banghart Spring 2017 Membro di Cal Poly, Team S15-G4, Banghart Spring 2017
CPSU-BANGHART-S17S15G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 686
