Introduzione
The power cord is what provides power to the motor, once its plugged in. Sometimes these can become stripped and worn down, therefore they may need to be replaced. Following this guide will give you detailed instructions on how to remove the power cord.
Cosa ti serve
Turn the blender on its side so the bottom panel is facing you.
Unscrew the 22mm Phillips #1 screw on the indent of the panel.
Unscrew the 3 screws in the rubber holes.
Unscrew the four nuts in the bottom of the motor cavity.
Wiggle the motor until it is free and you can remove it.
