Salta al contenuto principale
Waring 51BL29 Drive Coupling Replacement
Cosa ti serve
  1. Waring 51BL29 Drive Coupling Replacement, Bottom Panel: passo 1, immagine 1 di 2 Waring 51BL29 Drive Coupling Replacement, Bottom Panel: passo 1, immagine 2 di 2
    • Turn the blender on its side so the bottom panel is facing you.
    • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
    • Unscrew the 3 screws in the rubber holes.
  2. Waring 51BL29 Drive Coupling Replacement: passo 2, immagine 1 di 1
    • Remove the bottom panel.
  3. Waring 51BL29 Drive Coupling Replacement, Drive Coupling: passo 3, immagine 1 di 1
    • Place the screwdriver in the head of the middle flat-head screw.
  4. Waring 51BL29 Drive Coupling Replacement: passo 4, immagine 1 di 1
    • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
    • This screw may be reverse-threaded.
  5. Waring 51BL29 Drive Coupling Replacement: passo 5, immagine 1 di 1
    • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
Conclusione
Altre 4 persone hanno completato questa guida.
Dean Becker
Membro da: 04/17/17
470 Reputazione
4 Guide realizzate
Cal Poly, Team S15-G4, Banghart Spring 2017 Membro di Cal Poly, Team S15-G4, Banghart Spring 2017
CPSU-BANGHART-S17S15G4
4 Membri
5 Guide realizzate
1Commento della guida
Do you happen to know where I can purchase this replacement part?
Jessica Dye - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 38
Tutti i Tempi: 8,470
