Salta al contenuto principale
Wahl Professional Designer Power Switch Replacement
Cosa ti serve
  1. Wahl Professional Designer Power Switch Replacement, Power Switch: passo 1, immagine 1 di 2 Wahl Professional Designer Power Switch Replacement, Power Switch: passo 1, immagine 2 di 2
    • Unscrew the 12 mm Phillips head screws located at the top of the cover and at the bottom two corners, using a Phillips #1 Screwdriver.
  2. Wahl Professional Designer Power Switch Replacement: passo 2, immagine 1 di 2 Wahl Professional Designer Power Switch Replacement: passo 2, immagine 2 di 2
    • Unscrew the two black 5.556 mm Phillip head screw on the power switch with a Phillips #0 Screwdriver.
  3. Wahl Professional Designer Power Switch Replacement: passo 3, immagine 1 di 3 Wahl Professional Designer Power Switch Replacement: passo 3, immagine 2 di 3 Wahl Professional Designer Power Switch Replacement: passo 3, immagine 3 di 3
    • Shimmy the power switch off the mount until it is completely removed.
Conclusione
USF Tampa, Team S14-G5, Boczar Fall 2017 Membro di USF Tampa, Team S14-G5, Boczar Fall 2017
USFT-BOCZAR-F17S14G5
2 Membri
10 Guide realizzate
Un commento
Hello Mrs/ms Swearengin, I’m disassembled my Wahl desingner I’m unable to make the power switch stiff . It’s very loose I can’t recall which screw goes in between two black 5.556 mm Phillip head screw or if it needs a screw at all
Carlos Olvera - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 687
