Salta al contenuto principale
Wahl Lithium Ion Trimmer Metal Razor Arms Replacement
Cosa ti serve
  1. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement, Metal Razor Arms: passo 1, immagine 1 di 1
    • Examine the razor to identify any broken or jammed blades that require replacement. If any such blades are identified, the whole set must be changed.
  2. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: passo 2, immagine 1 di 1
    • Unscrew the two Phillips screws that hold the blades in place with a Phillips #0 screwdriver.
  3. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: passo 3, immagine 1 di 2 Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: passo 3, immagine 2 di 2
    • Apply pressure to the back side of the blades while pushing outward to remove the blade head completely from the Wahl Lithium Ion Trimmer.
  4. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: passo 4, immagine 1 di 3 Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: passo 4, immagine 2 di 3 Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: passo 4, immagine 3 di 3
    • Remove the metal clip using a Phillips #0 screwdriver.
  5. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: passo 5, immagine 1 di 1
    • Separate the Wahl Lithium Ion Trimmer head into its four components. Remove the damaged blade and replace it with a new one.
Conclusione
Altre 3 persone hanno completato questa guida.
3 Commenti
Where can I get replacement arms?
Sam - Replica
Where can one obtain a new spring???
tinkrmann - Replica
The spring popped out of the head, but your pictures are too blurry to see how it goes back together.
Mark Wilson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 68
Tutti i Tempi: 19,044
