Salta al contenuto principale
Wahl Lithium Ion Trimmer Electric Motor Replacement
Cosa ti serve
  1. Wahl Lithium Ion Trimmer  Electric Motor Replacement, Electric Motor: passo 1, immagine 1 di 1
    • Refer to the 4th step in disassemble process to begin replacement of motor.
  2. Wahl Lithium Ion Trimmer  Electric Motor Replacement: passo 2, immagine 1 di 1
    • Remove the chip set, battery and motor as one piece.
  3. Wahl Lithium Ion Trimmer  Electric Motor Replacement: passo 3, immagine 1 di 1
    • In this step focus on the motor, ignoring the chip set and battery. Here you will be able to remove the motor from the wires.
  4. Wahl Lithium Ion Trimmer  Electric Motor Replacement: passo 4, immagine 1 di 1
    • After the wires are removed and the motor is detached use the replacement motor you purchased and reconnect the wires.
Conclusione
Un commento
Did you actually find this motor (or an equivalent) for sale? Where?
Marshall Eubanks - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 24
Tutti i Tempi: 2,899
