Salta al contenuto principale
Wahl Lithium Ion 5537C Blade Replacement
Cosa ti serve
  1. Wahl Lithium Ion 5537C Blade Replacement, Shaver Blade: passo 1, immagine 1 di 2 Wahl Lithium Ion 5537C Blade Replacement, Shaver Blade: passo 1, immagine 2 di 2
    • Take out the batteries by pulling off the cover from the back and once done put the cover back on.
  2. Wahl Lithium Ion 5537C Blade Replacement: passo 2, immagine 1 di 3 Wahl Lithium Ion 5537C Blade Replacement: passo 2, immagine 2 di 3 Wahl Lithium Ion 5537C Blade Replacement: passo 2, immagine 3 di 3
    • Using the Phillips #0 screwdriver, remove the two screws on the blade and place them in the container.
    • Detach the blade from the body of the shaver and also remove the blade supporting mounts.
  3. Wahl Lithium Ion 5537C Blade Replacement: passo 3, immagine 1 di 3 Wahl Lithium Ion 5537C Blade Replacement: passo 3, immagine 2 di 3 Wahl Lithium Ion 5537C Blade Replacement: passo 3, immagine 3 di 3
    • Grab the replacement new blade and before mounting the support mount clean it with the cleaning brush to remove any dirt.
    • Place the supporting mount back to the new blade making sure it is properly attached.
  4. Wahl Lithium Ion 5537C Blade Replacement: passo 4, immagine 1 di 3 Wahl Lithium Ion 5537C Blade Replacement: passo 4, immagine 2 di 3 Wahl Lithium Ion 5537C Blade Replacement: passo 4, immagine 3 di 3
    • Place the blade with mount attached to the trimmer such that the screw holes are visible through
    • Grab on the blade hard and torque both screws one by one.
    • Check if the blade is attached tightly to the trimmer.
    • Insert the batteries inside the trimmer and start using!
Conclusione
Osman Saeed
Membro da: 07/11/21
109 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 65
Tutti i Tempi: 1,521
