Salta al contenuto principale
Wahl Chrome Pro Power Switch Replacement
Cosa ti serve
  1. Wahl Chrome Pro Power Switch Replacement, Case: passo 1, immagine 1 di 1
    • Remove the two 5.0 mm JIS #1 screws to loosen the cutting blades.
    • Make sure your device is not connected to power before you begin.
  2. Wahl Chrome Pro Power Switch Replacement: passo 2, immagine 1 di 1
    • Lift the bottom blade straight up from the device body to remove it.
  3. Wahl Chrome Pro Power Switch Replacement: passo 3, immagine 1 di 1
    • Remove the three 9.0 mm JIS #1 screws attaching the base of the blade assembly to the body.
  4. Wahl Chrome Pro Power Switch Replacement: passo 4, immagine 1 di 1
    • Lift the base of blade assembly straight up off of the body.
  5. Wahl Chrome Pro Power Switch Replacement: passo 5, immagine 1 di 1
    • Remove the two 12.0 mm JIS #1 screws on the back of the device body.
  6. Wahl Chrome Pro Power Switch Replacement: passo 6, immagine 1 di 1
    • Remove the 13.0 mm Phillips #2 screw on the side of the device body.
    • This screw is located on the opposite side of the body from the switch.
  7. Wahl Chrome Pro Power Switch Replacement: passo 7, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Remove the spring on the side of the body using tweezers.
  8. Wahl Chrome Pro Power Switch Replacement: passo 8, immagine 1 di 1
    • Pry the body case off of the device using a spudger.
  9. Wahl Chrome Pro Power Switch Replacement, Power Switch: passo 9, immagine 1 di 1
    • Remove one 7.5 mm JIS #1 screw connecting the power cord to the switch base.
  10. Wahl Chrome Pro Power Switch Replacement: passo 10, immagine 1 di 1
    • Remove one 7.5 mm JIS #1 screw connecting the wire to the switch base.
  11. Wahl Chrome Pro Power Switch Replacement: passo 11, immagine 1 di 1
    • Remove the switch from device by lifting straight up from the device body.
Conclusione
Holly Dunn
Membro da: 11/09/17
104 Reputazione
1 Guida realizzata
IUPUI, Team S7-G3, Baechle Fall 2017 Membro di IUPUI, Team S7-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G3
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 15
Tutti i Tempi: 582
