Salta al contenuto principale
Wacom Cintiq 24HD Stand Replacement
Cosa ti serve
  1. Wacom Cintiq 24HD Stand Replacement, Stand: passo 1, immagine 1 di 1
    • Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
    • Unplugging the cables by pulling on the cord or pulling at an angle can damage the cable or connector.
  2. Wacom Cintiq 24HD Stand Replacement: passo 2, immagine 1 di 3 Wacom Cintiq 24HD Stand Replacement: passo 2, immagine 2 di 3 Wacom Cintiq 24HD Stand Replacement: passo 2, immagine 3 di 3
    • Place the device screen down on a flat surface.
    • Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
  3. Wacom Cintiq 24HD Stand Replacement: passo 3, immagine 1 di 1
    • Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
Conclusione
Cal Poly, Team S15-G3, White Fall 2018 Membro di Cal Poly, Team S15-G3, White Fall 2018
CPSU-WHITE-F18S15G3
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 35
Tutti i Tempi: 1,997
