Introduzione
The power port in the Wacom Cintiq 24HD can fail over time due to overuse. The power port must function in order for the Cintiq to work. This guide will show you how to replace the power port. Soldering skills and tools will be needed for this replacement. iFixit has a guide to soldering which you can find here.
Cosa ti serve
Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
Remove one 11.9mm Phillips #1 screw from the center of the back panel.
Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
Detach the small black wire connecting the back metal plate to the USB video port by removing the one 8 mm Phillips #2 screw from the back metal plate and turning the screwdriver counterclockwise.
Remove the two 7.8mm Phillips #2 screws from the right back panel connected to the power port by turning the screwdriver counterclockwise.
Altre 3 persone hanno completato questa guida.
7 Commenti
My 24 HD blue power light comes on and off about once a second, you can hear the fan start and stop. Is a faulty power board the reason or is it the ps block ?
Is there any where I can get this part the circuit board is damaged
any information regarding where to buy this component
Can anyone tell me what size the capacitors are on the power port daughter board of the original 24HD Touch (DTH2400)?
DigiKey Part Number
2092-KPJXHT-4S-S-ND
