Salta al contenuto principale
Introduzione
This guide shows you how to take the back panel off of the Wacom Cintiq 24HD. It is a prerequisite for other replacement guides for this device. You will need a Phillips #1 Screwdriver and a plastic opening tool.
  1. Unplug any cables from the USB, power, display or DVI-D ports  by  gripping the  cord by the connector and pulling straight out of the port.
    • Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
    • Unplugging the cables by pulling on the cord or pulling at an angle can damage the cable or connector.
  2. Place the device screen down on a flat surface. Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise. Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
    • Place the device screen down on a flat surface.
    • Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
  3. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  4. Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
    • Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
  5. Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise. Remove one 11.9mm Phillips #1 screw from the center of the back panel. Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
    • Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
    • Remove one 11.9mm Phillips #1 screw from the center of the back panel.
    • Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
    • Our device does not include the cover panels for the USB, DVI-D, and power ports. You must first remove these cover panels shown in green in order to remove the back panel.
  6. Lift the back panel up by a corner and  insert a plastic opening tool in the gap. Slide the tool along the gap around the perimeter of the  device while lifting to  unlatch the back panel.
    • Lift the back panel up by a corner and insert a plastic opening tool in the gap.
    • Slide the tool along the gap around the perimeter of the device while lifting to unlatch the back panel.
    • The latches on the back panel will make loud clicking noises when opening.
    • Remove the panel by lifting it up and off of the device.
Conclusione
Sydney Hosokawa
Membro da: 08/10/2018
194 Reputazione
2 Guide realizzate
Cal Poly, Team S15-G3, White Fall 2018 Membro di Cal Poly, Team S15-G3, White Fall 2018
CPSU-WHITE-F18S15G3
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 50
