Introduzione
This guide shows you how to take the back panel off of the Wacom Cintiq 24HD. It is a prerequisite for other replacement guides for this device. You will need a Phillips #1 Screwdriver and a plastic opening tool.
Cosa ti serve
Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
Remove one 11.9mm Phillips #1 screw from the center of the back panel.
Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
