Introduzione
This guide shows how to remove and replace any of the four motor and pump shock mounts for the Wacker Pump PT3A 2012.
Note: There are several versions of this device, and each uses a different shock mount design that’s incompatible with the others. Contact Wacker Neuson with the device serial number, and they will confirm which mount you should order for the device.
Cosa ti serve
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Carefully rotate the device so that the pump sits on top of the engine.
Place a block of wood underneath the engine so that the engine weight rests on the wood and not the shock mounts.
Use a 13 mm socket and wrench to remove the nut(s) securing the shock mount(s) that you are replacing.
Use a 19 mm socket and wrench to remove the bolt securing the shock mount to the assembly.
Remove the shock mount.
Repeat to replace the remaining shock mounts.
