Salta al contenuto principale
Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement
Cosa ti serve
  1. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: passo 1, immagine 1 di 2 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: passo 1, immagine 2 di 2
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Loosen the belt guard: passo 2, immagine 1 di 1
    • Use a 1/2" socket and wrench to loosen the two bolts securing the belt guard.
    • The bolts are captive and should not be removed.
  3. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: passo 3, immagine 1 di 2 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: passo 3, immagine 2 di 2
    • Remove the belt guard.
  4. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: passo 4, immagine 1 di 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: passo 4, immagine 2 di 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: passo 4, immagine 3 di 3
    • Use scissors or a blade to cut the drive belt.
    • Remove the drive belt.
  5. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Install a replacement belt: passo 5, immagine 1 di 1
    • Loop the replacement belt onto the small pulley.
  6. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: passo 6, immagine 1 di 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: passo 6, immagine 2 di 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: passo 6, immagine 3 di 3
    • Replacing the belt poses a substantial pinching hazard. Wear safety gloves and be mindful where you position your fingers.
    • Guide the belt over the top of the clutch pulley.
    • Loop the belt underneath the pulley axle.
    • Rotate the pulley slowly and guide the built into the groove.
    • Getting the replacement belt back onto the drive pulley requires considerable strength.
Conclusione
Arthur Shi
Membro da: 01/03/18
254.622 Reputazione
529 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.430 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 36
Tutti i Tempi: 3,033
