Salta al contenuto principale
Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement
Cosa ti serve
  1. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Safety precautions: passo 1, immagine 1 di 2 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Safety precautions: passo 1, immagine 2 di 2
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Loosen the handle: passo 2, immagine 1 di 2 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Loosen the handle: passo 2, immagine 2 di 2
    • For ease of access, swing the transport wheels underneath the plate compactor before you begin.
    • Use a 3/4" wrench to remove the two nuts securing the handle.
    • Use your palm to push against the shockmount to prevent it from slipping.
    • Remove the nuts and washers and retain them for reassembly.
  3. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Lower the handle: passo 3, immagine 1 di 3 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Lower the handle: passo 3, immagine 2 di 3 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Lower the handle: passo 3, immagine 3 di 3
    • Tilt the guide handle forward to pivot the shockmount bolts out of the base grooves.
    • Slide the guide handle down enough to access the shockmounts.
  4. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Remove the shockmount: passo 4, immagine 1 di 2 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Remove the shockmount: passo 4, immagine 2 di 2
    • Pull the shockmount out of the guide handle.
Conclusione
Arthur Shi
Membro da: 01/03/18
313.348 Reputazione
729 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.735 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 736
