Salta al contenuto principale
WRS315SDHW Freezer Thermistor Replacement
Cosa ti serve
  1. WRS315SDHW Freezer Thermistor Replacement, Safety precautions: passo 1, immagine 1 di 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Freezer Thermistor Replacement, Open the doors: passo 2, immagine 1 di 3 WRS315SDHW Freezer Thermistor Replacement, Open the doors: passo 2, immagine 2 di 3 WRS315SDHW Freezer Thermistor Replacement, Open the doors: passo 2, immagine 3 di 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Freezer Thermistor Replacement, Remove the drawers: passo 3, immagine 1 di 2 WRS315SDHW Freezer Thermistor Replacement, Remove the drawers: passo 3, immagine 2 di 2
    • Remove the drawers and shelves from the freezer section.
  4. WRS315SDHW Freezer Thermistor Replacement: passo 4, immagine 1 di 2 WRS315SDHW Freezer Thermistor Replacement: passo 4, immagine 2 di 2
    • Remove the screw(s) securing the evaporator cover.
  5. WRS315SDHW Freezer Thermistor Replacement, Unclip the evaporator cover: passo 5, immagine 1 di 3 WRS315SDHW Freezer Thermistor Replacement, Unclip the evaporator cover: passo 5, immagine 2 di 3 WRS315SDHW Freezer Thermistor Replacement, Unclip the evaporator cover: passo 5, immagine 3 di 3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. WRS315SDHW Freezer Thermistor Replacement, Remove the evaporator cover: passo 6, immagine 1 di 3 WRS315SDHW Freezer Thermistor Replacement, Remove the evaporator cover: passo 6, immagine 2 di 3 WRS315SDHW Freezer Thermistor Replacement, Remove the evaporator cover: passo 6, immagine 3 di 3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. WRS315SDHW Freezer Thermistor Replacement, Unclip the thermistor: passo 7, immagine 1 di 3 WRS315SDHW Freezer Thermistor Replacement, Unclip the thermistor: passo 7, immagine 2 di 3 WRS315SDHW Freezer Thermistor Replacement, Unclip the thermistor: passo 7, immagine 3 di 3
    • Use a spudger to push the tip of the thermistor through its slot in the wire harness.
  8. WRS315SDHW Freezer Thermistor Replacement, Disconnect the thermistor: passo 8, immagine 1 di 2 WRS315SDHW Freezer Thermistor Replacement, Disconnect the thermistor: passo 8, immagine 2 di 2
    • Disconnect the thermistor from the wiring harness.
  9. WRS315SDHW Freezer Thermistor Replacement, Remove the thermistor: passo 9, immagine 1 di 1
    • Remove the thermistor.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro da: 04/14/15
15.885 Reputazione
88 Guide realizzate
Global Fixers Membro di Global Fixers
Community
30 Membri
501 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 94
