Introduzione
Replacing the Intel Centrino Wireless Chipset with a component that meets the same standard.
Cosa ti serve
Unlock the battery latch on the right.
Unlock the battery lock on the left.
Remove the battery pack from its slot.
Using the Philips # 0 screwdriver, unscrew the 2 screws of the top cover
Check the marks indicating the direction in which the cover must be removed.
Remove the bottom cover by removing it in the direction of the markers.
Here is the WLAN Chipset / Bluetooth
Gently unplug the MAIN and AUX antennas.
Unscrew the fixing screw with Philips # 0 screwdriver.
To reassemble your device follow the following instructions in reverse order
Un ringraziamento speciale a questi traduttori:
100%
irlanda ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
