Salta al contenuto principale
Introduzione
If you need to replace a Brad Nailer Pressure Regulator Knob, follow the steps outlined in this guide. For this guide, you will need a 2mm Allen wrench. The steps outlined are relatively easy to follow.
Strumenti
Parti
Nessuna parte specificata.
  1. Using a 2mm Allen wrench, remove the Allen screw located on the pressure regulator knob on the back of the brad nailer.
    • Using a 2mm Allen wrench, remove the Allen screw located on the pressure regulator knob on the back of the brad nailer.
  2. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  3. Remove the knob from the gun and replace the knob.
    • Remove the knob from the gun and replace the knob.
    • Be aware of the rubber spacer that will come off with the knob; when you replace the knob put the spacer back in the middle around the screw hole.
Conclusione
Ousman Jammeh
Membro da: 17/09/2018
507 Reputazione
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 55
