Salta al contenuto principale
WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Chamber Gasket Replacement
Cosa ti serve
  1. WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Chamber Gasket Replacement, Pressure Regulator Chamber Gasket: passo 1, immagine 1 di 1
    • Using a 4mm Allen wrench, remove the 4 Allen screws, 44mm in length, from the yellow cap on the back of the brad nailer.
  2. WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Chamber Gasket Replacement: passo 2, immagine 1 di 1
    • Remove the yellow cap to reveal the gasket.
    • Keep the nailer upright so the piston does not fall out. If the piston falls out, simply put it back in place.
  3. WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Chamber Gasket Replacement: passo 3, immagine 1 di 1
    • Remove the faulty gasket and replace it with a new gasket.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 253
