Salta al contenuto principale
Vulcan Venture II VNB14002IE I/O Board Replacement
Cosa ti serve
  1. Vulcan Venture II VNB14002IE I/O Board Replacement, Back Panel: passo 1, immagine 1 di 1
    • Use a J00 screwdriver to unscrew the 10 back-plate screws.
  2. Vulcan Venture II VNB14002IE I/O Board Replacement: passo 2, immagine 1 di 1
    • Gently separate the back panel from the laptop.
  3. Vulcan Venture II VNB14002IE I/O Board Replacement, I/O Board: passo 3, immagine 1 di 1
    • Locate the IO board on the back panel.
  4. Vulcan Venture II VNB14002IE I/O Board Replacement: passo 4, immagine 1 di 2 Vulcan Venture II VNB14002IE I/O Board Replacement: passo 4, immagine 2 di 2
    • Locate the ribbon connector on the IO board, and lift the black bar closest the the ribbon.
    • Pull the ribbon cable away from the connector, releasing it.
  5. Vulcan Venture II VNB14002IE I/O Board Replacement: passo 5, immagine 1 di 2 Vulcan Venture II VNB14002IE I/O Board Replacement: passo 5, immagine 2 di 2
    • Locate the screws on the IO panel, and use the J00+ bit to unscrew them.
  6. Vulcan Venture II VNB14002IE I/O Board Replacement: passo 6, immagine 1 di 1
    • The IO Board is now safe to remove from the computer.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 531
