Parti
Nessuna parte richiesta.
Hold the on/off button for 3 seconds until the screen is black.
  • Hold the on/off button for 3 seconds until the screen is black.
  • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
  • Turn camera upside down to allow the batteries to fall out.
Aggiungi Commento
There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
  • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
  • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
  • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
  • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
Aggiungi Commento
  • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
Aggiungi Commento
  • With the back plate off, use a screw driver to remove the 6 screws shown to the left.
  • Gently separate the circuit board from frame, by prying the circuit board from base.
Aggiungi Commento
  • Using your finger rotate the dark grey piece away from the shutter button.
Aggiungi Commento
  • Remove the shutter button by gently pressing the button from the top, pushing it towards the inside of the camera. Press shutter button down and wiggle slightly until the shutter button comes loose from housing.
  • Replace as necessary.
Aggiungi Commento
Conclusione
Baylor, Team 8-15, Williams Fall 2014 Membro di Baylor, Team 8-15, Williams Fall 2014
BU-WILLIAMS-F14S8G15
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 78
