Cosa ti serve
There are two screws that require a 4.0mm flat head screwdriver. Twist them counter clockwise to remove. When you remove them they stay contained within the blue outer case.
Remove 6 screws in order to pop off the outer shell and reach the inside components.
When the white cover and the ball motor have been removed, the 6 push buttons will be easily accessible. 3 of the buttons can be removed from their slots by gently pulling up on each. The other 3 buttons are located lower in the unit and are held in by 1 phillips screw each.
Remove the two 9mm phillips head screws, located on either side of the speaker housing.
Remove the solder from the wire connections on the speaker by heating the solder joints with the solder iron and pulling on the wire at the same time.
Solder the wires to the new speaker by touching the wire to the speaker contact while heating with the solder iron and feeding solder wire into the joint.
