Introduzione
This guide will walk you through replacing the USB port on your childs Vtech InnoTab 3S.
Cosa ti serve
While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
Remove the batteries from the device.
Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
Remove the six 3 mm screws securing the battery clip.
Using the tweezers, remove one battery clip from each corner (four total) of the Vtech InnoTab 3s.
With the tweezers, unsecure the charging port, headphone port, and the light switch button from the front panel of the device.
Facing the underside of the USB port, solder the metal prongs securing the USB port to the device.
