Salta al contenuto principale
Vtech InnoTab 3S Rear Panel Replacement
Cosa ti serve
  1. Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: passo 1, immagine 1 di 3 Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: passo 1, immagine 2 di 3 Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: passo 1, immagine 3 di 3
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S Rear Panel Replacement: passo 2, immagine 1 di 2 Vtech InnoTab 3S Rear Panel Replacement: passo 2, immagine 2 di 2
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S Rear Panel Replacement: passo 3, immagine 1 di 3 Vtech InnoTab 3S Rear Panel Replacement: passo 3, immagine 2 di 3 Vtech InnoTab 3S Rear Panel Replacement: passo 3, immagine 3 di 3
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S Rear Panel Replacement: passo 4, immagine 1 di 1
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
Conclusione
USF Tampa, Team 8-2, Eyestone Fall 2015 Membro di USF Tampa, Team 8-2, Eyestone Fall 2015
USFT-EYESTONE-F15S8G2
4 Membri
9 Guide realizzate
Un commento
too dumb i tryed 7 times it didnt work i reat this 1000000-/10
Kyron Ostrander - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 656
