Salta al contenuto principale
Vtech InnoTab 3S Motherboard Replacement
Cosa ti serve
  1. Vtech InnoTab 3S Motherboard Replacement, Rear Panel: passo 1, immagine 1 di 3 Vtech InnoTab 3S Motherboard Replacement, Rear Panel: passo 1, immagine 2 di 3 Vtech InnoTab 3S Motherboard Replacement, Rear Panel: passo 1, immagine 3 di 3
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S Motherboard Replacement: passo 2, immagine 1 di 2 Vtech InnoTab 3S Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S Motherboard Replacement: passo 3, immagine 1 di 3 Vtech InnoTab 3S Motherboard Replacement: passo 3, immagine 2 di 3 Vtech InnoTab 3S Motherboard Replacement: passo 3, immagine 3 di 3
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S Motherboard Replacement: passo 4, immagine 1 di 1
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
  5. Vtech InnoTab 3S Motherboard Replacement, Motherboard: passo 5, immagine 1 di 2 Vtech InnoTab 3S Motherboard Replacement, Motherboard: passo 5, immagine 2 di 2
    • Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
    • Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
    • Remove the six 3 mm screws securing the battery clip.
  6. Vtech InnoTab 3S Motherboard Replacement: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using the tweezers, remove one battery clip from each corner (four total) of the Vtech InnoTab 3s.
    • With the tweezers, unsecure the charging port, headphone port, and the light switch button from the front panel of the device.
    • Potential for device damage: Avoid forceful movements when removing the motherboard to prevent damage of device components.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 8-2, Eyestone Fall 2015 Membro di USF Tampa, Team 8-2, Eyestone Fall 2015
USFT-EYESTONE-F15S8G2
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 548
